Pansat 3500 power on/off | SatelliteGuys.US
dflores020563
3
I got a Pansat 3500 receiver, when I connect the cable coming from the dish it starts to power on/off.
Does anybody got an idea why?
Regards.
Pansat 3500
Igot two anntenas one of 6 feet and another of 3 feet, I am in the Dominican Republic.
Maybe a short in your coax or LNBF, I would try a new cable, then an other LNBF.
It is a good idea to power the receiver off (via the rear main switch) before connecting any cables, switches, or LNBFs.
Not doing this can fry any switch you may have in the line, and possibly the LNBF.
I only wath FTA Channels
I changed the cable and I solved the problem but Now I only see FTA channels.
After I run the Scan the channels seems to be there but I can not see or listen anything. I just can see the FTA.
I downloaded nad installed the last bin but stil not working.
Glad my suggestion of changing the cable worked :D
Very sorry to hear you are a simple thief :mad:
NO HACK TALK!
BANNED :devil:
Pansat 3500SD no signal lock ku
