Pansat 3500SD and DVB-S2 | SatelliteGuys.US
dennise
37
After several enjoyable years watching Montana PBS on AMC21 (Ku), MT PBS today switched to DVB-S2 format. Both my Pansat 3500SD and MT PBS have served me well until now.
Am I wasting my time attempting to reprogram my 3500SD to get DVB-S2?
Is DVB-S2 possible on 3500s.
Is there a kit or upgrade I can get for DVB-S2.
Help .....!!
No,and No, the 3500 is SD only. Sathawk/solomend/Openbox time.
Just to qualify,
I know the 3500 is SD only and I'm happy with SD. Is DVB-S2 strictly HD only?
Government upgrades usually have some degree of backward compatibility so I doubt an upgrade such as DVB-S2 would render all SD equipment useless.
So, is there any possibility I can still use my 3500 with DVB-S2 for SD TV?
dennise said:
Just to qualify,
Lets make it simple for ya denise..
Pansat 3500 = NO DVB-S2 in HD or SD period.
Hope that helps
Hope that helps
Well ............ that about sums it up. Looks like it's time for new 'box'.:mad:
Any idea how long DVB-S2 will last?
well its the new thing so I assume a while
S2...more programs in less space with same picture results
Here to stay like Iceberg said it.
Need a good and cheap DVB-S2 unit? Look for Coolsat 8000 on ebay. Sometimes u find some for very cheap. You can even check for the Coolsat 8100 model which ebay had 2 sold recently for under $80
Hi all, another option that I did not see mentioned would be a PC DVB-S2 card. If you got this route you will need a reasonably strong PC for the HD.
Later, DC
amc9 gone?
Any fall FTA projects?
