Pansat 3500SD no signal lock ku | SatelliteGuys.US
barret
47
Please help. I have a Pansat 3500SD that I am unable to get the ku signal quality to lock. KU quality on various satellites anywhere from 40 to 99% but signal quality meter will blink on and off constantly. I have sucessfully tuned the c band side and have various stations programmed including the MPEG test signal. I am in upstate NY, have an 9' mesh dish, .6 dB lnb and the Uniden Supra receiver. I am having no trouble receiving good clear stations on the analog ku side on various satellites across the arc from amc 6 to galaxy 10R. I have tried repeaking the dish while the digital side ku quality meter is flashing and can get signal quality as high as 80% but still no lock. The dish uses a button hook style mount and I am wondering if the focal point could be off or could the mesh dish be a problem with the digital side. I contacted FTA direct with my problem and they referred me to this site as the best possible place to get help. I am a junior member and hope I am posting in the right area. Again please help.
:confused: barret
Remember Digital KU signals are harder to find (Tweak) than C-Band digital or even analog.
I would double check the dish alignment as it may work perfectly for C-Band but will need some fine tuning for KU band!
Tron, just read your reply. Thanks. Just got home and too dark to go up to roof to check exact size tonight, although I know the hole diameters are too small for a pencil to go through.
Thanks barret
If they're too small for a pencil, the dish will be fine for Ku.
Possibly you'll have to fine-tune for Ku. I hear that is often necessary with a BUD (Big Useful Dish).
SuperBowl Sunday
Pansat 3500 power on/off
