pansat 3500SD | SatelliteGuys.US
pansat 3500SD
gaby
10
I'm looking to buy this receiver.
is there any one who knows about this sytem?
What did you want to know about it?
What do you currently have for dish/LNB/motor or are you buying that too?
It's a good box. That's what I have. The fact that it's got am sd card is very nice because it allows you to save your channels and stuff on to a card that you can move between your box and your computer for fast editing in channel master - some other boxes require you to hook up a physical wire to the back of the box. Also, using that sd card you can play mp3s.
there is some channel that you can get only through disch network.
can I get these channels?
a Dish500 wont work for 99% of the chanenls out there. For FTA you need a 30" dish or larger and a KU Band LNB
So you bought a satellite system and you do not know what channels you want to get or on what satellites they will be?
I'm new to this satellite world and I'm trying to get the pansat 3500SD and see what I can get with.
Iceberg
with the super dish, I mean if I put the super dish, would it be better for the channels?
Math nerd question
Travertine Channel on IA8
