Pansat 5000 HDD(transfer)? | SatelliteGuys.US
newbiebutnotforever
31
Hi guys and welcomeback,
I have a question, I have songs on my PC and I would like to transfer it to my Pansat to be able to listen to it in my room, First thing I do not know if this could happen or not? and second thing, I do not know if Pansat can play Mp3s or not?
And the same thing when I record a show and I want to transfer it to my PC?
Any suggestion any answer would be appreciated :)
Don't know about MP3s, but to transfer a show from your hard drive to PC would probably require a DVD recorder if you are able to connect one. I have a Pioneer 220s and use it to record stuff and then transfer it to PC in order to burn a DVD that will work in any player. Takes a litle time but it works.
It sounds more difficult than what I was thinking on, because both of the reciever and the PC have a hard disk, its wierd that there is no easy way to transfer files throw the USB connector, I wished if there were.
Anyway good to hear from you and thanks for the suggestion and Happy thanks givingssssssssssss
Amc 9 and mytheatre?
Galaxy 10R Problems
