pansat 9200hd dvbs2 module install | SatelliteGuys.US
rrob311
941
16
New England
I picked up an older dvbs2 module for my pansat 9200 and I am unable to get any signal or quality with s2 transponders. Is there a special firmware I need? I am not sure if this board is bad or not. It is like it is disconnected. The instructions I got are vague.
what software version are you running?
Like Mikey said there are 2 boards out there.....the actual S2 board and the "illumini" or 8PSK board which is designed only to (at the time) steal Dish Network
right sw for s-2 with s2 blind scan
there are 3 boards
1) turbo 8 illuminatti (dish)
2) s-2
3) s-2 with s2 blind scan
when in smart scan go over the dvb and move to the right on cursor should go to s2 mode
good luck
Ya I did that. When in smart scan mode the Tuner type is not selectable. I am pretty sure this is the older non blind scan model.
LNBF Test Comparison: SL1PLL, PLL321S-2, Chaparral
Intelsat 9 is down :(
