PATRIOT LNB questions | SatelliteGuys.US
Flinthill
104
West Central Texas
Does anyone use the PATRIOT brand of LNBs? They appear to be the same as NORSAT and even use the same part numbers, but are priced much lower than Norsat.
I believe Satellite Engineering Group sells them even cheaper. Do a Manufacturer search for Norsat. There isn't much descrpition on their site. You have to know what you are looking for. They are very easy to deal with though.
mkm4, I just checked SEGs site and you are right. SEG is about 15% lower than the best price I had found any place else, The runner up vendor is Mech-Tech in Evansville, IN. Thanks a lot, you just saved me over $30 bucks.
