PBS on AMC21 | SatelliteGuys.US
PBS on AMC21
Gary Z
942
Seguin, Texas
Just got the sonicvoom ac3 decoder setup for PBS and was wondering if Titan has those channels in the guide and what do I enter? I don't get the HD., but I get MontanaPBS, Create, and PBS World.
Thanks Iceberg.. I was looking for the Titan codes for MontanaPBS, Create, and PBS World. After re-reading my original post I see I was not clear as to what I meant... sorry :)
Montana PBS
KUSM
KUFM
PBS World
WGBX-DT2 is a 24/7 channel
Create
WGBX-DT3
I use WDSE-DT3 for Create as its a "local" station. My local PBS has its own version of Create with other programming on it
Hello Gary
just a quick question. Does the Sonic voom did the work of decoding the AC3?? I'm in the process of getting one
Thks
Hello Gary
Thks
Yep decodes the audio just fine and passes the normal audio. You can plug computer speakers in to the Sonic voom or use one of the following connectors to connect directly to the RCA input on your TV
Pls Pls help with prof 7300!!!!!
Super Dish lnb
