Pegasua and card for stb | SatelliteGuys.US
geocole
12
HI New th HDTV. I bought a used SAT 520 STB and called Pegasus to see what I would need to do about getting a new card for it. They said it would cost $90.00 for a new care and $45.00 if it came with a used one.
IS this normal??
Thank You
IS this normal??
Thank You
Where are you located?
You should be able to call Directv and get a card for $20 from them and get yourself switched over to Directv instead of Pegasus. 1-800-DIR-ECTV.
Pegasus card
I live in San Antonio Tx
I sent the paper work in to Direct to get swiched over.
Thanks for the Info
Geo.
DirecTV newbie
DirecTV Fall promotion
