phone line to reciver | SatelliteGuys.US
mdram
4,082
810
Md
i have a 622. i was thinking about ditching my landline for a bt gateway and cell service. there is no high speed available to me, i use cell wifi
how often does the reciver call out? and how long are the calls?
i could possible use a bridge and connect it to my cells wifi, but then i would have to be home when it used the net
just wondering
just wondering
I don't know if Dish receivers support it but you'd have to use a laptop to get online then use a cross over cable (cat 5) and run it to the receiver. (That's how you do it with a ps3) That's if your using Data Connect device.
just wondering
You don't need to worry about it. Dish no longer gives you a credit for having it connect, so who cares if it is.
as of right now the receiver dials out once a month. Its a very short call..from what im told its under a minute. it sends a status containing the software version, signal str and some other metrics that analyze the condition of the receiver. Besides that, you can pay bill and order pay per view/VOD. if you dont do those things dont stress about connectivity. Dish no longer waives the TV2 fee if its connected. that all changed FEB1 of this year.
722 skip back problem.
Dish doing too well?
