Phony address | SatelliteGuys.US
Phony address
mfoster711
357
22
College Station, Tx
I have heard of people using a phony service address with Dish so they can get locals from a different market. Is this really possible? Also, curious if Dish even cares. If I live in New Mexico but wanted to get all New York locals, why would Dish care since I am paying them the same regardless.
Dish really does not care. Your local broadcast stations do.
The problem is that the locals alot of time are on spot beams. As such they dont cover the whole US. So it may be possible to lie to Dish to subscribe to different locals, but you may not be able to receive thm.
"Moving" has to do with having an address that can get other locals yes. The problem is you have to be able to get a signal for those locals. NYC locals aren't going to work in NM. All the NYC local channels are on spot beams that are aimed at NYC general area. Those spot beams are covering an area not much bigger than 300 miles. So in summary no way you are going to get NYC locals in NM anywhere.
I am getting the major NY locals from Florida in SD. WNET and some other minor channels are on spot but the others come in ok.I am about to drop DISH though because they dropped all NY RSNs.
better check the uplink report ;)
That's a reason why eventually you won't see any on CONUS, only NYC remains on WA and the plug will be pulled sometime this year on the EA. Bye bye long range movers.
Hopefully that will be enough to please the big 4 (at least the O&O) so they won't try to squeeze more $.
Big 4 +WPIX & WWOR have been in SD on CONUS forever.
Allstate commercial with E* dish
Not getting Sat 129
