What receiver were you using?I used to have one of those. But, the peice of junk had the dreaded StarzHD drop-out problem.
P.S. resize your pictures
Thanks for doing that will do on next post.Please use the attachment option next time to make the pics thumbnails. Then folks can click to see the full size
Thanks!
Do you know the pinout from the MMAP Port to HSI input on HDD-1000?
I also have a DSR 920.
Thanks kbghdg,
I will try DB9
4 - HS+
9 - HS-
5 - Gnd
If that does not work i will switch 4 and 9.
Limited time offer
