Picking up 129 on existing eliptical | SatelliteGuys.US
zoldy
4
Ontario
Hello. I have an existing Eliptical that is currently picking up 110 and 119 perfectly. The bracket i have has slots to pickup 91 and 101 but not 129. I have a separate round dish picking up 91 as well. Since I want to get 129 I thought I would set an LNB in the eliptical and move the round dish to 129. Or change the bracket to include 129. I am having trouble getting 91 or 129 on the eliptical. What I don't understand about 91 is the bracket is supposed to be pre set for it. And I would assume since I am getting 110 and 119 perfectly then it is aligned correct.
I cant imagine I am the only one with this problem. Perhaps my dish is skewed the wrong way? Can someone tell me when using a bracket that does 91 101 110 and 119 which way the dish should be skewed in ontario canada... near toronto
I see now I can choose multi LNB from the website. I missed that. it says that my skew is 109 degrees .... I will see what I am currently set at
Well still no luck in fact worse when setting way found on the website. Is it possible my bracket is not for my dish? my bracket says 91 101 110 119. I am trying to get 91 110 and 119. I can get no signal at all from 91. My dish is a small eliptical. I am starting to wonder if the bracket is for a larger dish. I can get 110 and 119 really clear.
Any other suggestions. I do have another round dish as well currently aimed at 91. Was trying to move this to other dish to use round dish for 129
Is it easier for me to get 110 119 and 129 on the same dish with a different bracket perhaps?
Thanks in advance.
Switching From Dish to at&t U-Verse tv service
WildBlue on Satellite F-2 Is Temporarly Down
