While watching TNT I noticed that TV1 the picture is fine, however when I switch to TV2 and put on TNT the picture will be jittery. It only happens on TNT. It is a 722K and rebooting it does not fix it.
Any ideas
Sounds like 1 of 2 things. Are you watching it on another TV not in the main room? I have a feeling that there is line loss and may need a line amp. Other possible thing could be that the channel you are on has OTA interference from a digital channel. See if changing the channel that is outputting from unit works better if you switch it to another channel. Look up what channels are really braodcast and be sure you are a couple away from those.
The receiver is setup in single mode and I do not have an OTA module.
In my OP I made a typo. It was not TV1/TV2. I meant to say tuner1 and tuner2 while in single mode.
That's what he said in his original post....
Is it only TNT?
Yes, only on TNT. I have checked the other channels and TP and only TNT is showing that issue. However today I have not seen the issue appear. But I have seen it happen twice within 7 days.
Limited time offer
