Picture keeps freezing up | SatelliteGuys.US
lsh1885
SatelliteGuys Guru
133
Orlando, Florida
The picture keeps freezing up on both TV"s. I have a 3rd TV that is hooked up to a 811 receiver and it is fine and is not effected by this problem. I will try to reset the receiver and see if that helps. Beyond that does anyone have any ideas as to what the problem might be?
I'll assume you did a soft reboot (holding in the power button for 10 seconds).
Try a hard reboot (pull the power cord for 30 seconds).
What have the other threads on freezes suggested?
I did try a hard reboot, it did not work. I didn't think about the soft reboot. I tried that and apparently that did the trick. It has not frozen up since. Thanks!
Well, I am now back to square one. After going this long without a problem, the picture is freezing up again. I was not able to get much help from the searched threads as it mainly was dealing with Directv equipment and about the receivers being defective. I am not sure if that is the case here yet. I am going to call Dish amd see if they can help.
Help Just bought new sony 34 widescreen picture looks bad
dish remote codes ??
