picture pixeling on Fox 43 lancaster PA | SatelliteGuys.US
jwalker
lancaster PA
I have directv and fox 43 pixels quite often. Directv told me its a fox broadcast issue. So I called fox and they said that they are not having any broadcast issues...is anyone else having this issue?
The picture will pixel from 1 to 10 seconds....every 5-7 mintes....so this is annoying.
I had a service guy here and he pretty much changed everything...LNB, Splitters...the signal is from 94-100 on all channels.
Jeff
see if you can get the local HSP's # and ask, sometimes there is an ongoing issue with that type of problem (we were actually dealing with it here on all HD locals, but i think its finally fixed) and D* doesn't know about it unless the proper paper work is done about it on the HSP side.
I try to see if they know anything because it would suck to get the last tech back charged for something thats D* or the broadcasters fault if a truck roll is generated
Jeff
My FOX 17 in nashville does the same thing!!! really annoying!!!
D12-500 is dead
DTV breaking up.
