Picture Position Shifts Up | SatelliteGuys.US
GreatMac
SatelliteGuys Guru
124
It seems that the picture of the Voom HD channels is pushed up when using DVI. When watching OTA HD, the picture position is perfect, but when watching Voom channels the picture shifts upward in varying degrees: on some channels just a bit, on some a lot. Plus there is a small rainbow square in the lower left.
Anyone else with this problem? Is there a solution?
:confused: :confused: :confused: :confused: :confused:
Yes, I see the same problems on certain channels.
On certain VOOM channels I notice a black at the bottom as if the picture is shifted up and not square. But it is not in all programs on even the same channel.
So, it seems like some of the Voom channels are a little off in their positioning.
Hope they fix it.
Would I be an idiot to signup?
Voom Phone Line
