I'm getting a high quality picture on channel 3 (TV1), but a much lower quality picture on channel 60 (TV2). Why?!? This is an interesting situation that I'm hoping someone technical can shed some light on... here are the details.
Running a 522 dual tuner. I have the TV1 output going out over one coax line, and TV2 going out over the other coax line. The entire house is wired with a double strand of coax (run through several slitters, through the attic and basement - at least 300ft of line, maybe 400ft). By simply reconnecting at the wall jack, I can make any of the TVs in the house see either the TV1 output on Channel 3, or the TV2 output on Channel 60.
The channel 60 output is consistently lower quality on the remote TVs. At the TV next to the tuner - both channels are high quality - so it is not the 522 that has a problem.
I've completely switched wires with no affect (reversed the wires that the receiver is feeding between TV1 and TV2), so it is not that one wire has a cut in it, or a bad splitter.
My suspicion is that the frequency that channel 3 broadcasts on carries better over longer distances, versus channel 60 degrades faster over longer distances. Is that possibly true? (I'm not technical). If so, would a line amplifier likely help?
Are there other possibilities?
-Mike
-Mike
