Picture/sound stutter on sd | SatelliteGuys.US
FredC
105
Chicago, IL
Hey all. Something has been going on with both my sd dual receivers (522 & 625). While watching live tv, the pic will freeze/stutter/jump (how do you want to describe it?!). The weather can be clear or cloudy, day or nite (mostly watching at nite) with signal strength around 70. I've seen sim. discussions with hd, but not sd. Any ideas??
It seems like there must be a problem with the LNB since both receivers are experiencing the problem. Then again, it may be a mirror of the problem with the HD DVRs.
Do you know if both receivers are running the same software version?
All my 522/ 625s are doing this too.
there appears to be a problem.....
I am also getting short recordings:( Anywhere from a few minutes in total length to 57 minutes, miss end of show.
wierdly I have 2 seperate LNB feeds, one using a quad, one using a sw34
how strage is that. its been going on since the card swap
I'm not sure what program they are using, I would assume the most recent as they automatically update.
I don't know if its the LNB, but I haven't noticed a problem with my 508 & 510.
I have all the receivers hooked to one dish. The 522 has 2 lines from a quad feed, the rest are fed via a 44.
Kinda sounds like a software issue
Recover deleted events on 522
Making OTA Channels the Default
