PIN changing by itself? | SatelliteGuys.US
  • Thread starter Thread starter david13579
  • Start date Start date
  • Replies Replies 0
  • Views Views 848
david13579
15
NY
We have a 625 receiver and we had it set for different PINs for TV 2 and TV 1, but today (after about a month or so of doing anything requiring a PIN) when I tried to input the PIN of TV 2 and it did not work, and R rated tv programs are locked, what is weaird is that only I knew the PIN and I didn't not change it. Also TV reseted its PIN, when I went to check if it also had problems I found out it had no PIN set but no one has taken off the PIN number.
The only different thing we have done recently was connect the phone line to the receiver (we never connected it because it was affecting the DSL signal but after gettng better filters it now works).
So, is it possible that the PIN could change by itself?.
A new use for your slingbox and smartphone
SlingGuide - Problems
