pixelation and blue screen | SatelliteGuys.US
lowe41
I live in Atlanta, on the Fox affiliate (HD) tonight every 5-10 minutes or so the channel would pixelate and I would get a blue screen for about 5-10 seconds and the picture would come back just as normal. So far I have only seen it on the Fox channel. I have never seen a blue screen though?? Have any of you guys? If so any idea as to what causes this? my reciever? Dish alignment? Is it the local affiliate? I have an H20-600 and all the signal strengths are 85+ most in the mid to upper 90's.
Any info would be greatly appreciated.
Secondly, anyone in the Atlanta Metro that has experienced the same issue let me know.
I have also had the exact same thing happen on my local Fox HD channel! It makes me feel better that other people are having the problem so it's most likely not a problem with our setups. Besides that issue I've been very impressed with the picture quality on the channel. Hopefully it's something they will work out over time.
Same problem in south florida
This has been happening here also for the last few weeks on the local Fox affiliate only. So annoying I switch to a different input and use an indoor antenna when I want to watch Fox.
Thanks for the reply, it makes me feel better as well that its probably not my setup. Hopefully they fix it soon, its kind of annoying during games especially... Like I said, I have seen pixelation many times, just not the blue screen?? Kind of wierd.
Thanks again.
HD Programming coming to Spike TV HD.
DNS tech screwed up...
