to Satelliteguys Watty!
I can't id the make, but it looks like it's fiberglass so it's going to be pretty heavy. I'll bet it weighs at least 100 lbs.
[/QUOTE
Motorized... High voltage?Yes that is a BirdView. Very well made dish. But will need some fixing to bring up to current standards. It is a very heavy H to H motorized mount.
It takes 36 volts DC.Motorized... High voltage?
36vdc good info. Thank you.It takes 36 volts DC.
But you will need to build a pulse position sensor to work with modern dish motor controllers, like the VBox or ASC1.
The original Birdview position sensor was an analog variable resistor. Modern controllers use pulses. I built a magnet wheel disc and used a reed sensor to create pulses when the motor rotates.
There are various threads on this site for building a magnet wheel position sensor. If you are interested I can find them for you.
The problem is the pole its mounted on....to Satelliteguys Watty!
The pole is the pro lem. Heavy rust @ tbe base.Leave the existing pole and buy another from a local supplier or recycler.
The pole has heavy rust @ the base and must go. This home is down town phoenix, and is recognized as a historic building. The homeowner wants it all gone.Leave the existing pole and buy another from a local supplier or recycler.
Limited time offer
