FOR SALE - PLX3402 AUDIO AMP for the pros it weighs about 30 pounds | SatelliteGuys.US
FOR SALE PLX3402 AUDIO AMP for the pros it weighs about 30 pounds
(((Garyd)))
Retired C-Band dealer
29,407
24,664
diamondsatellite@snet.net
I'm looking to get the best offer, shipping will be the bummer it's heavy.
Does it work, I do not know, I picked it up from someone who had no idea what it even was, I assume his dad was going into a nursing home, or his grandfather, from the serial number I was able to figure out it was made in the USA in 2001 its looks very clean the output posts to speakers were not tied, but loose, so he may have used it.
I'm a retired electronic tech who has worked on amps like this in my life, and I did not even open it up, if I did I would be asking more, but I assume he bought it, and never used it, so the best way to make sure is to fire it up with a speaker load, and use an AC power source that is adjustable start at 30 volts AC then over the next 5 minutes slowly come up to full power, I can get my hands on one, I did have one many years's ago until I burned it up.
Then listen, if no hum is heard with volume up, reduce volume ad your input signal source and play it,
My gut says it's a good unit.
My location is 06488
