If you’ve recently lost access to standard definition local channels on DIRECTV, you’re probably not too happy. Listen to this week’s podcast and you might understand the process a little bit. Plus, call Signal Connect at 888-233-7563 to find out innovative ways to keep local channels on satellite.
Listen to the podcast your way!
Just choose one of the following:
Option 1: Click on the image above to stream the podcast in your browser. If you use the YouTube player above, be sure to subscribe to get future videos delivered to you!
Option 2: The Solid Signal Podcast is available on several podcast aggregators. Search for us, or tap on the links below on your mobile device. If you want us to add another aggregator leave a comment below.
Option 3: Download the podcast in MP3 format.
Option 4: Paste the following link into your favorite podcast app:
Looking for older podcasts? Check them out on our YouTube channel!
The post Podcast #575: DIRECTV is TAKING AWAY local channels? Why? WHY WHY!! appeared first on The Solid Signal Blog.
Continue reading...
