Pointing Dish 1000.4 | SatelliteGuys.US
Chris04626
118
MAine
Im trying to point a dish to 61.5 and 77 I have managed to pick up real quick Mexico 77 or something and a nimiq one time But not getting anything near 61.5
I have my elevation set to what dishpointer says, with the little rod, How do i set the skew on this thing,i found where it says skew on the side but if i losen those nuts i cant get it to turn, i took the nuts off and the whole dish fell off, Im not seeing how its supposed to turn
You loosened the wrong set of nuts. Log into Dish's website and download the manual for your dish.
Ok i figured it out
Ok dishpointer says this
Elevation: 38.2°
Azimuth (true): 171.9°
Azimuth (magn.): 188.8°
LNB Skew [?]: -5.7°
how do i set at -5.7
Ok i figured it out
Elevation: 38.2°
LNB Skew [?]: -5.7°
Make sure you're selecting the "1000.4 (61.5W, 72.7W, 77W)" setting in the "Multi-LNB" section of Dishpointer.com. Your skew in Maine should be somewhere between 91 point something and 95 point something depending on your exact location.
Recent RSN Moves
Breakup and pixelation on KATU Portland, OR
