Pointing Dish for local channels in SW Virginia | SatelliteGuys.US
mikemcreynolds
Southwest Virginia
Where do I point the dish to receive local channels on a round dish in Southwest Virginia? Azimuth and angle?
I've read something about 72.5 on other sites but nowhere, even on directv's site, have I found clear settings for local reception; nothing appears on the receiver either. I'm receiving regular programming quite well, most houses in this rural area have 2 dishes, one for local. I self install and don't know where to point my local dish. Thanks for any help.
what market? Tri-Cities?
what dish do you have right now? If you have just the single LNB dish then its possible your locals are on 72.5 (Lyngsat shows that but the Direct site doesn't)
D site shows that "some local channels require a MPEG4 receiver" so there are a couple options to go with. SInce you mention the neighbors have 2 dishes you would need a 2nd dish at 72.5 and a 22k multiswitch (or a 4x4 multiswitch depending on how many receivers you have)
or just call D* and ask..they might have an upgrade offer because checking their site the locals are in HD too (the big 4)
To the OP - You DO know that those locals ARE in the process of migrating (dual-feed) to MPEG4 already, & that 2nd dish will NOT work after around the end of this year anyway...
As Ice told you, you be MUCH better off calling D* & letting them upgrade everything for FREE themselves... ;) ;)
Has sat 119 stopped transmitting?
Noob HR22 Question
