Pointing Dish to EA | SatelliteGuys.US
Pointing Dish to EA
Peter123
9
Ithaca NY
Guy, I see some differences in the pointing angles to EA stalellite depending
where I am getting the number from:
From Satellite Finder / Dish Pointing Calculator with Google Maps | DishPointer.com
Using My address In Ithaca, NY 14850
Elevation: 38.7°
Azimuth (true): 158.3°
Azimuth (magn.): 170.4°
LNB Skew [?]: -15.8° Dish Skew [?]: 90.0°
From DishNetwork Insatllation PDF
Using ZIP: 148XX
Elevation:41 Azimuth:184 Skew:85
There is not much difference in the published elevation angles (<3deg),
However, the differende in the azimuth and skew angles are significant.
What is the source of the difference, which is right?
Peter
I get this when I put in your ZIP code:
Address: 14850
Latitude: 42.4355°
Longitude: -76.5257°
Satellite: Dish 1000.4 (61.5W, 72.7W, 77W)
Elevation: 40.8°
Azimuth (true): 174.4°
Azimuth (magn.): 186.5°
And:
Your Location Satellite Data Dish Setup Data View dish alignment line in Google Earth
Latitude: 42.4355°
Name: Dish 1000.4 (61.5W, 72.7W, 77W)
Distance: 37718km
Elevation: 40.8°
Dish Skew [?]: 85.8°
Turn counter-clockwise standing behind the dish
Address: 14850
Latitude: 42.4355°
Elevation: 40.8°
And:
Latitude: 42.4355°
Distance: 37718km
Elevation: 40.8°
Rick which dish pointing database are you using?
Peter
So thisis the same as the dishpointer web-based app is telling me.
But the question is why the data publisd in the Dishnetwork PDF file is SO different?
Peter
Upgrading from 722 receiver - -free upgrade?
UHF Remote Battery Issue
