Poor Audio on a Couple of Channels | SatelliteGuys.US
yanks2402
Enjoying FiOS TV
155
Tampa, FL
Does anyone else notice poor almost "tinny" audio on certain channels. Everything else with Verizon has been stellar, but this audio bug is driving me crazy. The best way to describe it is mono, compaired to a strong sounding stereo.
I only notice it on FX, Discovery, and Comedy Central, so to me that rules out the possibility of being an equipment problem on my end.
Can anyone confirm a similar problem. Thanks for your help.
i just checked those three channels and they sound ok to me.
can you check your abc hd and see if your soccer is in hd? both my ota and fios feed are in sd and loosing sound right now. i am assuming it is an abc problem.
Yeah, both my FiOS and OTA are SD, did not notice any sound problems though...
hd switched turned on for me right before halftime. audio still goes out every five minutes. i have to switch channels for it to come back.
Viewers Switching To Verizon (Tampa Area)
Comcast Chattanooga Adds 3 Removes 1!
