Claude, I'd like to be able to say I'm surprised at what you are seeing, but I can't. I've got a number of friends with Dish and I'm the only one using OTA at all, even though you can get at least 2 of the major broadcast networks, and usually 3 or more with nothing more than a set of indoor glorified rabbit ears.
This is not a very popular item...
Not surprised either. I've seen reports of OTA viewership in the 10-15% range. The vast majority of people still associate antennas with "snowy" pictures on TV. People tend to think visitors to this site are "the average Joe", but they're not !Claude, I'd like to be able to say I'm surprised at what you are seeing, but I can't. I've got a number of friends with Dish and I'm the only one using OTA at all...
Dish included an OTA tuner in the 622 and 722 and then do you recall them doing a survey regarding OTA viewing ? Not long after, the 722k was released WITHOUT the OTA tuner. Put 2 and 2 together to figure out why....Maybe DISH should of included the ota tuner in the 722k from the start...
Maybe DISH should of included the ota tuner in the 722k from the start and added ota antenna to your install, and then everyone would of known of the ability to record 4 shows at a time.
For those without a clue: Most people were NOT using an antenna, therefore Dish was putting money down the drain including this piece of hardware that was sitting idle !
Huh ?But now that the subchannels are available Over The Air maybe we wouldn't have so many when is Dish Network going to add these channels on satellite threads if Dish Network would have included the tuner(s) in the 722k?.
Why do you say the 622 and 722 are more popular ? Dish REMOVED the OTA module from their newer receivers (722k, 922, 222k) for a reason. Some might like to say it's because Dish is cheap, but my money says it's because Dish knows the OTA simply wasn't being used by most.I also believe this is what makes the 622 and 722 more popular because it has the OTA tuner built in.
Limited time offer
