is it a special proprietary hd or have special software in it that prevents it?Neutron said:Nope.
correct me if im wrong, but if someone found a way to flash the firmware it might be possible to do this right?Neutron said:I believe it's because something in the firmware is programmed for a certain size hard drive and brand.
Im not all that worried about it, just figured it'd be nice to have some more room. I could always burn to dvd if need be to clear up some room, its a digital>digital connection right (i.e. if dvr saves dolby digital, if i send it to dvd it will keep it too??)SimpleSimon said:Apparently, there are some non-lease 522's out there, but even so, the DMCA prohibits you from screwing with the thing.
That's NOT true with 501/508/510 boxes. Yahoo groups dishmod & dishrip.
Who's going to modify their box and then even expect Dish to fix it if it breaks ??BFG said:Dish doesn't allow swapping HD's because they don't want to be servicing a bunch of broken DVRs when people break them for putting in in compatible drives.
Limited time offer
