Power Inserter Dpp 44 | SatelliteGuys.US
yellowcanary73
SatelliteGuys Guru
135
I know the inserter should be put on port 1 but the other day when the so called tech was here he was switching all of the lines to the 44 switch around can this damage anything.
No!
Port 1 is the only port than can accept power, supplying switch and lnbs.
It is the same voltage as receivers put out.
While the cables were switched, power would have been supplied by whatever receiver was connected to port 1.
Most configuations do not need anywhere near the 1.65 (~2 max) amps that the inserter can supply.
My own testing has shown a DP receiver can supply over 1 amp. This is enough to power DPP44 in most cases, without using power inserter. (not recommended)
HD channels 9466 and 9467.
I upgraded Dish Network HD last week
