Power saving option on Hopper? | SatelliteGuys.US
Diversify
26
DC
I have my hopper set up with a Slingbox adapter. This works great. But I noticed that the hopper turns it self off after a X amount of time and then I can not access it anymore with Dish online. Is there a Power save option on the Hopper that I can adjust or turn off? Or is there another solution to this?
Thanks in advance.
I just found it under: setting: Diagnostics: Updates. But is that is kind of weird. I kinda get the feeling if I disable this, I also disable updates. Why heck is it under updates? Does anybody know?
At 1 AM it will go into standby for updates and reboot no matter what you set on the timeout screen.
Dpp 119, 110 and 61.5 on separate dish?
Hopper Timers gone?
