“Prepare for Mobile” Setting | SatelliteGuys.US
DawnB
75
53
Ripley, TN
There used to be a setting somewhere in the Hopper 3 that you could turn on "prepare for mobile" so that the H3 would automatically do that....and when you went to transfer a recording to a mobile device, it would be ready to go. SOMEHOW, that has gotten turned off on my H3, and I can't figure out how to turn it back on, and am now having to have each recording prepare before I transfer them, which is driving me insane. Does anyone remember/know where that setting is????
Sent from my iPad using the SatelliteGuys app!
Sometimes, when my receiver gets a firmware upgrade, it resets some settings. This doesn't happen all the time, but I have seen it happen more than once (I have a HWS receiver). Turning it off and on again was a smart thing to try.
Yes, and the last update reset or upset my DVR Timer Defaults without my knowing about it and consequently a newly set Timer started minutes LATE, so I missed the beginning. Some timers have to be set MORE than ONE minute before because one week it starts no more than a minute early, and some days they can start more than TWO minutes early. This usually occurs for those :05 beginning times as displayed on the EPG and in clear type marked for Start Time of the program. Now, I have to keep a look out for when an update is downloaded so I can check ALL my defaults because there were other defaults for the DVR that were also changed the last update. Found out the hard way.
Reactions: pattykay
Receiver not showing scheduled timers
weird with receiver
