Preset satellites | SatelliteGuys.US
Preset satellites
cigarman
6
I have a SV 8000 HD I had a lot of preset satellites on my box when I started now I only have 9. I tried factory firmware no help can you help guide me? Thank you
Cigarman,
I am not really familiar with your model, but generally speaking if you just dump the firmware into the box, it does not always apply. You often have to perform a factory reset or factory set or a restore procedure (whatever they may call it) in your box menu.
It is almost akin to rebooting your PC when you install a new program or an upgrade to existing software. It keeps running with the old version of the file until the system is rebooted somehow.
I am not sure if that is the case for your situation, but I would read up on it.
RADAR
i have this wild blue dish
White Springs is missing again
