Prime Time Anytime | SatelliteGuys.US
Prime Time Anytime
uptownvideo
178
13
I was wondering if there is any way that I can set record Prime Time Anytime to record using my over the air antenna. I do have the antenna plugged in to my Hopper receiver. I am trying to save on my monthly bill since I have a good antenna. Thanks.
No, PTAT is dependent on the four networks being on the same transponder. If you have a Hopper 3, however, you could set timers for each network individually for those hours and get what you want. With 16 tuners, using 4 at a time is no biggie...
No, that is not possible. PTAT works because all of the prime-time TV stations are on the same transponder so Dish can record all events on that transponder at once. Your OTA channel does not use a satellite transponder, it is over the air, so it has to be recorded separately.
EDIT: I guess Bobby types faster than I do! :)
Since when does the Hopper 3 support 4 OTA tuners? It sounded like the OP wanted to drop the satellite locals to save money.
Reactions: joegr
...For that matter, if you record the (satellite-delivered) four major networks at the same time, they always share the same tuner, whether you use PTAT or not. :)
Hopper & 722
DishAnywhere.com doesn't show Video On Demand movies on PC
