Primestar ? | SatelliteGuys.US
Primestar ?
newtoo
2
post falls idaho
can i use a primestar/channel master 84E reflector 29.9"highand 39.5" wide to pick up fta sats will it work , i have a sadoun standard fss dual lnbf kul2 to use with it ?
Yes it will. Iceberg has one of those, I think...he'll see this and I'm sure tell you more. Primestars are excellent dishes. I have the bigger ones. 2 of the 1.2 meter and 2 of the 1.0 meter size.:)
Makes a great fta dish!! And yes they have been motorized by some members here, I remember seeing pics of one a while ago.
Have two of them and they work great for FTA satellites
(actually have 3 but one isnt installed yet) ;)
2nd pic has a Sadoun dual LNB on it (and a DBS one for 119)
You might consider using the original feedhorn and possibly LNB if you have them.
Should work fine.
Show us some pictures and describe them if you want to go that way.
Using your newer LNB from Sadoun is fine, too.
I'm sure you can come up with a simple way to mount it.
Great dish to put on motor
Heres mine
please help
Need help with 97 (Intelsat AM5)
