Tonight PrimeTime Anytime decided not to record anything. The guide shows the PT symbol as if they are scheduled, but they are not recorded. I think this has happened before when we were not home and shows were just not there.
The settings were not changed and it was still on. Under Schedule it was gone off the schedule for the one day showed for the day before and after. Is there a way to accidentally cancel it for one day?Go into settings and make sure PTA did not get turned off somehow. I have had a single show or two not record at times, but never the whole thing.
Josh is from DISH. It is safe to send him your receiver number.Can you DM me your receiver number?
I have the same problem. ABC is checked in PTAT, but shows do not record. Do not see 'PT' in the guide. The other 3 networks are fine. DISH technician could only suggest replacing the Hopper3.Just very odd that this seem to happen at random. Worked fine the day before and will probably work fine today. Nobody else has had this happen occasionally?
Limited time offer
