problem finding 129 | SatelliteGuys.US
problem finding 129
I have a dish 1000.2 and i found sat 110 and 119 but not 129 so what am i doing wrong
thanks
jim
You might off on your adjustments. Cover the 110 LNB with aluminum foil and see if 110 goes to 0. Do the same with 119, you'll know if you are catching the right birds with right LNBs.
Exactly. You've probably (probably) got the dish pointing a few degrees too far east and a couple of degrees too low. If you can't be bothered to run back and forth, just swing it to the right until 110 and 119 tone again, at which point, you'll probably hit 129, and then peak it from there.
Help for All American Direcet Channels
National Network Channels
