Problem playing VIP211 HDMI thru Onkyo AV Receiver | SatelliteGuys.US
chc59
95
15
Dalton, Ohio
Got a new Onkyo AV receiver. The HDMI output from my VIP211 will not play thru the receiver. Plays ok going direct to the TV. Have two other HDMI output devices working fine going thru the Onkyo. Changed cables and inputs around but always with the same result. Appreciate any thoughts/hints that you might have. It's a bummer having to use component video output.
Joe
Can't comment on the Onkyo setup, but component has no less PQ than HDMI.
What model do you have??
I did a google search...no video through onkyo hdmi
Seems to be a problem on some models.
I had a similar issue with my 606 but it was my own fault. I had another piece of equipment which I had assigned HDMI 1 and Optical 1 to say input SAT. After I hooked up my 211 to SAT input I got video but no sound. I had to go into the setup of the receiver and remove my optical assignment after which I was good to go. Moral of the story is check how you have your HDMI and Digital audio inputs set in the On screen menu...
Missing HD channels, 722 receiver on Dish 500
tv2 receiver telephone connection
