Problem Pointing Dish | SatelliteGuys.US
bonezzz
2
I have a new VIP 622 receiver from Dish Network. I have a Dish 1000 for HDTV purposes. I have had problems when pointing the dish. I keep getting the error message that which says one of the inputs or switches is not connected properly.
When I go into the intallation menu under Point Dish to select the dish type, there is no option for Dish 1000. The only choices are 300, 500, and Super.
Which Dish should I select in the menu (500 or Super)? Also, what else should I do to trouble shoot this receiver, dish, and the cables for this connection error message?
Specs:
VIP 622 Receiver
Dish Network 1000 Dish
Dish Pro
DP Plus
DP Plus Seperator
Thanks in advance,
bonezzz
Specs:
VIP 622 Receiver
Dish Pro
DP Plus
DP Plus Seperator
Thanks in advance,
bonezzz
Its essentially like a 500 with an extra LNB.
Signal Strength Question and Installation
And Baby makes 3?
