problem with LNB.? | SatelliteGuys.US
problem with LNB.?
oldtimer
24
I just added HBO and Cinemax and find I'm short 4 channels all on sat 110,
it appears I'm not receiving 110 on my dish 500 what gives the LNB switch.?
You need to run a switch check. This will tell you what type of LNBF or switch you have in your system. There are many different type of Dish 500 configurations. The switch check will also tell us weather you are seeing all your transponders.
Dishnetwork and RVing
New Install: how long can the ground wire be
