problem with pansat 2500 | SatelliteGuys.US
ckt
17
Hi guys, This is my first post so be gentle. I have been into FTA for a little over a year now thanks to this forum. My setup consist of Pansat 2500A, Twinhan 1020A, 30'' dish, Sg2100 motor and Invacom SNH-031 LNB. My problem is with the pansat, after several blind scans of different sats it would not let me select anymore satellites. I went to edit list and it was full of entries listed as new and would not let me delete any. I went to pansat web site and updated software 3 times but with no luck. I tried factory reset, this just removed the channels. Is there anyway to fix this or am i stuck watching with my twinhan and no blindscan?
confused on what you are asking
I have a 1500 which is the little brother of the 2500 and I have almost every satellite from 61-129 scanned in with no issues and about 400 channels in it
The receiver works but will not let me select any more satellites from the list. I read somewhere that if you blindscan to fast it will lock up
never heard of that. I do know that if you have too many transponders in the system it might shut down. Best thing to do is delete transponders except for 1 on the satellite before you scan.
How many satellites do you have stored in there? I have the following in mine (and their degrees in orbit)
Amazonas 61
AMC6 72
SBS6 74
AMC5 79
AMC9 83
AMC2 85
AMC3 87
IA8 89
G11 91
IA6 93
G3 95
IA5 97
AMC4 101
AMC1 103
AMC15 105
IA13 121
G10 123
H1 127
IA7 129
If i go satellite scan from menu it lists (NEW) over 120 times and T5 57 times
I just did a factory reset, selected T5 for a scan and the reciever turned itself off then on, now I can't select any satellites from the list.
Viacast Quantum 3000
33" Digiwave dish low signal
