I am having problem with the SA IPTV stream stopping
I am aware of the posting on buffering problems and don't believe that this falls under that category.
I've been on the phone with tech support about this multiple times and it is still unresolved, hence my posting here.
What happens is that I daily record Fox News Channel via DVD recorder and often the channel I'm recording just stops. Sometimes it buffers and then comes back, but more often it just stops, goes to the channel guide and of course it doesn't restart until I press 'play'.
Here's the current situation:
I have 6Mbps broadband, DSL and it regularly tests at 5.2 to 5.3Mbps
I only have one PC currently active on the connection
The IPTV box is connected by CAT5 cable to the router
The IPTV box speed test sees ~3.2Mbps, which as I understand it is the maximum the box can read
Have set the IPTV box to a static IP address
Have made sure the firewall on the Belkin router is disabled.
The IPTV box has been added to the 'DMZ zone' and top the best of my understanding it doesn't need to be on a particular port for that to work (unlike the Linksys routers).
Sky Angel (at least one Agent) has stated that recording with a DVD recorder can cause the streaming to stop, which I'm finding rather odd unless there's some sort of impedance mismatch.
I would think that most people today would be recording by DVD or TiVO type device.
Any ideas? Any help would be appreciated. I'm ready to end my subscription and get Dish or nothing at all.
