Problem with Winegard PM-2000/Direct TV | SatelliteGuys.US
BigSlim
Ca
I recently purchased a Winegard PM-2000 portable satellite dish so I could take my Direct TV with me in my RV. It states that it is Direct TV compatible, but I am getting no signal. I've double checked the settings, and all the hookups.
My question: Even though it says it's compatible with Direct TV, is it possible it is not? Could it be for another area of the country?
If so, can I just replace the LNB, or do I need a whole new dish?
Any help would be great.
That is a single sat dish, meaning only good for the 101 sat. So, it should be just fine for DirecTV's core programming. You need to verify the elevation setting. When I set up my original single sat dish I misread the scale for elevation.
What receiver are you using?
SWM Slimline DIRECTV SWS8WB-P Switch/Multiplexer troubles
Who installs a new receiver when bought at Best Buy?
