Problems conifguring sat | SatelliteGuys.US
feyerman
I have a channel master 1.2 system for internet use. I am in Afghanistan and i tried other means of tech support but i dont think they knew what they where doing. I can lock onto the satellite with out a proble, there are 3 i have to choose from. the W3 W1 and NSS6 for here. The problem comes when trying to lower the BER rate. I cannot get it lower than .001. the company needs atleast .0004 to be able to lock on me and activate my system. I have done everything I can think of. Polarization andle azmuth. I think there is some kind of problem with the equipment but the company refyses to agree with me on it. any help or fresh i deas would be appreciated.
If you've got the signal peaked as best as possible another thing that may help is adjusting the skew of the LNB. If the satellite is east of your location then try rotating the LNB slightly clockwise in the mount and see if that helps.
If these things don't work then you will need a better quality LNB that has a lower noise figure and/or a bigger dish. Invacom has some nice LNBs if you need one and the satellite uses linear polarization. They don't make one for circular polarization yet.
Are both lines required when using a multiswitch?
S
Altitude Sports tips off today
