Greetings, Gang!
I just switched to DISH this summer. I was housesitting, so the installer used the existing dishes on the roof to the 522 receiver. I'm not sure which dishes those were, exactly, but two coaxes came into the house and went to the #1 and #2 inputs on the back of the receiver. I really loved the DVR!
I'm waiting for my house to be built on my property and am living in an RV in the meantime. I'd used DirecTV portably for years without a problem. The dish was mounted on a tripod and it took all of 15 minutes to aim it with the help of the basic $35 analog signal meter. I was told that DISHMover did not support RVs, but I should be able to do this myself.
The installer at the house gave me a DPP dish to use later. I also have a basic twin LNB as an option. "Later" is here, and I'm having problems.:rant:
The RV has an input on the outer wall for a *single* coax. I tried setting up with a single coax cable from LNB connector #1 to the outside connection, then ran a single coax inside to input #1. I was able to get a 60 signal on 119, but couldn't pull in 110. When I tried again, I lost 119 but got 110. When I ran "check switch" the receiver recognized 110 but not 119. About that time my analog signal meter quit - it got no power from the receiver like normal. Now I don't know if that is a receiver problem or something in the meter fried??
I tried the old "open the window and max the volume" trick to hear the onscreen signal meter. Nothing. Then the receiver insisted on changing to either sat 105 or 129 on the signal strength page ALL BY ITSELF, no matter what I changed it back to. I don't have HD.
The first advanced tech rep I talked with said to use the DPP LNB and use a separator just before the receiver so there is input for both #1 and #2. That sounded good and I figured I'd get one Monday after the Xmas holiday.
Then I realized that one feature of having twin inputs to the receiver was being able to record more than just one - especially since I don't have a second TV.
I used the HughesNet dual coax (a mistake?) to run from both outputs on the DPP in through the window straight to inputs #1 and #2 on the receiver. I still couldn't get a signal tuned in, and "check switch" didn't seem to recognize the new configuration. We are talking less than 30 feet, so is line loss a factor?
I recall from somewhere that there is a Catch-22 at work here.....you can't get the onscreen signal meter to work properly unless the "check switch" function is working properly BUT the "check switch" function won't work properly unless it sees a valid signal. SHEESH! Of course, I did the hard off/on thing several times with the receiver, to no avail.
I would like to run two coaxes from the DPP LNB and don't mind doing some new "plumbing" in the RV for it if I can get increased versatility from the 522. All my coaxes were working fine before. I can run another resistance test on all of them again, I suppose.
Can I manually set anything on the "check switch?" Use regular (not satellite TV) coax? I really appreciate any help you can give me. I have just enough knowledge to be scary.
P.S. I just LOVE the RANT smiley!
