I Have a WS International Mod. YH KU-75-II dish (30") yes I know it may be a little small.
A rotor sat hh90 motor
A dynosat 5000 receiver
Dual LNB WSI Mod. ESX522U
My ZIP CODE IS: 17047
I made sure the pole is 100 percent plumb, mounted the motor and adjusted the Latitude to 40.4 and the dish elevation to 41.2 Deg. Also the motor is on "0" I faced the dish due south and have no obstructions. I connected the Lnb to the Lnb on the motor and the motor to input on meter, the output on meter to receiver and connected to tv.
I adjusted the antenna both on due south and elevation slightly to get the best meter reading. Removed meter .
I have the receiver screen on the tv, However it says no signal…I am guessing that the dish is set correctly and the problem is that the receiver needs info. The manual that came with the receiver is the worst manual I have ever seen. Not able to follow it as it seems to be written for a much advanced user. Where can I download one?
Any help would be greatly appreciated!
Sam
Sam
