Problems with downloading guide data | SatelliteGuys.US
Xstation
62
2
Hi, if anyone can help with this annoying problem I'm having, it'll be greatly appreciated. I have SL5 with a multiswitch in the 95127 area.
Recently I've been getting a message on screen every couple of days, saying that the "receiver has not been getting guide data updates and that a reset might solve the problem". Well I have no choice but to press OK and reset it. Couple of days pass by and I receive the same message.. sometimes during a recording.. some times (I guess it happens over night), because when I wake up the receivers lights are on.
I've read that the guide data is received via the 119 satellite, so I ran the satellite setup, and I see a red X on 119, but as you can see I am receiving a signal on it..
Satellite transponders (32 total at 101º) (4,12,18,20,26, and 28 are spotbeams)
1-8 96 96 95 100 95 98 95 99
9-16 95 97 95 100 96 100 95 100
17-24 95 0 95 100 95 100 95 100
25-32 96 0 96 52 97 100 95 100
Satellite transponders (3 total at 110º)(No spotbeams)
1-8 NA NA NA NA NA NA NA 97
9-16 NA 91 NA 95 NA NA NA NA
Satellite transponders (11 total at 119º)(25, 29, 31 are spotbeams)
17-24 NA NA NA NA NA 91 56 88
25-32 0 95 0 93 0 93 0 93
Satellite transponders (14 total at 99º(c))
1-8 84 89 84 85 80 87 83 85
9-16 80 87 81 83 85 89 NA NA
17-24 NA NA NA NA NA NA NA NA
Satellite transponders (6 total at 99º(s))(All are spotbeams)
1-8 0 0 0 0 0 0 NA NA
9-16 NA NA NA NA NA NA 96 0
17-24 0 0 0 0 38 49 94 94
[Note: these can be very slow to appear]
Satellite transponders (16 total at 103º(s))(All are spotbeams)
9-16 NA NA NA NA NA NA 99 49
17-24 100 100 76 53 0 0 96 0
[Note, these can be very slow to appear]
Satellite transponders (14 total at 103º(c))
1-8 86 91 86 85 81 85 84 85
9-16 83 86 85 86 84 89 NA NA
Wondering if anyone can check these numbers and tell me if they look good, and if not how can I tweak them (especially 119) so that I may be able to fix this problem..
Thanks!!
Numbers aren't too bad - could be a little better, but not bad enough to do that.
Pull the plug on the unit - wait 2 minutes - then plug it back in. The "hard" reset could clear the bug.
Remote Codes
the new 9 favorite channel screen
