Problems with Hotbird 13E, with a SeaTel control unit | SatelliteGuys.US
AmateurSat
8
Italy
Hi everybody, I have a very difficult situation. We have a seatel dish installed on a yacht which is controlled with a SEATEL DAC 2200 unit. That should be not a problem, as it's just like a plain dish, it just turns automatically etc..
The problem is, that some channels are boxed up, but in some part of the day they are working fine again. I think there might be something wrong with the set up. Maybe you could help? I think that POL might also be off, but where could I get information about the correct POL?
The receivers are: Samsung Digital Satellite receiver DSB-B350W
The settings on the dish control unit are:
SAT: 13E
THRS: 1595
FREQ: 1284
NID: 0000
AZ: 176.5
EL: 038.9
REL: 358.6
AGC: 1820
Baud: 27500
Tone: ON
Volt: Vert
Fec: 3/4
Also I wanted to ask you how do I get the Frequency? As the frequency I found on LyngSat for the channels which are mixed up is: 12597 Vertical
Names of the channels are: RTR Planeta and Perviy kanal Europa 12597 V, they work when they want...all the other channels work just fine.
Closed Caption and SAP (vip622)
Smartcard Expiration: Should I be worried
