Problems with skyway install | SatelliteGuys.US
apsc
58
Florida
having problems with skyway install AMC 15 can not get lock on skybeeper or birddog on amc4 either.:confused:
Problem solved not sure may need new Birddog 4.0
Where are you located?
Florida, figured out the problem. The skybeeper was bad and the file worked fine on a Birddog 4.0 i borrowed from a friend. I have a 2.5 it still works on everything else i sure hope it will work with this new skyway file they just uploaded.:D
